Hi, I have a Github Integration connected, I’ve updated some sources (minor update, only some commas or question marks are added) - during synchronization GitHub erases all my translations, but I would like to keep them. How can I force it not to erase? Best
Hi Kate, Github integration uses same rules as, for example, CLI, so it should be enough to add into configuration something like update option = update without changes
Oh, thanks for the tip, I always used UI configuration, never thought about YAML
I’ve just tried that - looks it works pretty well. But I’ve decided to go with an update as unapproved, so my proofreader can sort stings via filter (unapproved), and just to go one by one to double-check whether all looks fine.
Again, thanks!
