Today, GitHub Integration suddenly stopped working, and says “No crowdin.yml config”, when I tried to add a new one, the preview didn’t show anything.
So I delete Integration and recreate it, and now it stuck on save button, on F12 says “Failed to load resource: the server responded with a status of 500 ()”.
If you’re on free plan, you have a limit of 1 branch only. I’d suggest to delete the integration, delete the branch from Content (because of it exists you can add a new one) and set up everything via UI so system can create a new crowdin.yml for you.
