Hi, for personal needs I was forced to create one more Chinese language in my project (some techicnal things need for developer will be bound on this one).
Can I somehow connect it automatically with all my project? The existing one and the future one?
In enterprise you can create a project based on pre-made workflow, and if that w-flow includes that custom language, then it will be automatically added to the project. In crowdin I don’t think that this feature exists already. Maybe by API or so. Actually yes, but API you can create the project with some language set up, so theoretically it should allows you to add custom lang during creation, but never tried it to be honest
